DISTINCT query returns no results, subquery works fine?
Hi
I’m using InfluxDB shell version: 1.7.10
And when using this query:
select DISTINCT("INSTANCEID") from (SELECT "INSTANCEID","Users" FROM "instance_metrics" WHERE time > now() - 10m AND "status" =~/4/)
I get no results, but if i run just the subquery i get the results i expect
time                INSTANCEID Users
1600741611000000000 6857066537460510913      0
1600741611000000000 6888070296062469040      0
1600741611000000000 1263711974140952598      0
1600741611000000000 2593761205830678961      0
1600741611000000000 334541987675708369       0
1600741611000000000 8220649877065111672      0
1600741611000000000 4011148669846043396      0
1600741611000000000 4752283977825580341      0
1600741611000000000 4432841746050330361      0
I would like the INSTANCEID column values to be output as distinct values, i don’t understand why this is not happening.
What is odd, when i remove the status filter it seems to work:
select DISTINCT("INSTANCEID") from (SELECT "INSTANCEID","Users" FROM "instance_metrics" WHERE time > now() - 10m)
time distinct
0    1302080874926140461
0    1626446265035079180
0    1647823715233863344
0    2599762930576015105
Can anyone help ?
thanks.
Some more info might be useful:
  • some sample data (including the status “column”)
  • which tag and fields you have (and the field data type)
Also, what’s “status”? a tag? a field (and of which data type)?
If “Status” is a numeric field you cannot use the regex comparator "status" =~/{exprHere}/ but you have to use the standard "status" = 4
