I asked this question earlier but didn’t receive any responses. I’m posting again in hopes that someone has worked with the API or deleted data from their db.
I am trying to find a means to remove hosts from influx using the API. I’ve tried a variety of syntax similar to:
curl -i -XPOST 'http://localhost:8086/query?db=telegraf' --data-binary @/tmp/myinflux.txt
{"results":[{"statement_id":0}]}
myinflux.txt:
q=DELETE FROM system WHERE host = 'web001'
I can do this successfully via influx cli:
> use telegraf
Using database telegraf
What is wrong with the API command?
