Remove host from telegraf w/influxv2
I have an old host from my telegraf. I would like to remove it in influxdb. How can I do that?
Hello @rmo,
Do you mean you’d like to delete all of the data from an old host?
What version of InfluxDB are you using?
I’m assuming it’s a tag if so, you can use the CLI and follow this example:
OR the API
Assuming you’re using OSS and a version that supports the delete command :slight_smile:
