When I try to create a table in influx with 2 numerical values, it is displaying the data in tabular format. when I try to customize the decimal values to 3, it is not working, it is showing normal only.
Regards
Sudheer
Regards
Sudheer
Hello @AVVS_Sudheer,
you might need to just view the data in raw table format.
Alternatively try going to the settings and changing the decimal Places value.
I tried all the ways, But only for table format it is not working, for remaining visualization types it is working. I tried to keep 3 or 4 or 5 after decimal. it is working fine.
Regards
Sudheer
