I did a mistake when I imported data in influxdb.
My field was with the type float and I insert some data with the type string. Now, I cannot anymore write float data in this field. Is there a way to deal with this problem? I wrote the data with the python api.
I could delete the measurement or write in a new field, but I do not want. The only solution I know for the moment is to delete the Database.
Someone know another solution?
Thank!!
Gaëtan
I found a solution to my problem. I post it if someone else has the same problem.
The steps are:
- duplicate the measurement just with float:
select value::float into “duplicate” from “mymeasurement”
- remove the measurement:
drop measurement “mymeasurement”
- copy again the in your measurement:
select value::float into “mymeasurement” from “duplicate”
- remove the duplicate measurement:
drop measurement “duplicate”
thx for your post, but after doing as you post, the influxdb has a high IO usage.The target measurement has 18,000,000 records.
