How can I do date manipulations in TICKscript?
In my alerts I want to show for what time period the batch query ran. My query is running for now and now() - 2h.
I want to show in alert that, query was run for period 10:00 to 12:00.
Hi ,
this will work for you , you may have to adapt it it to be more dynamic …
it is just an example to inspire you
var message = ' The query period was {{ index .Fields "beginhour" }}:00 - {{ index .Fields "endhour" }}:00 '
var data = stream ...
data
|eval(lambda:hour("time"))
.as('beginhour')
.keep()
|shift(2h)
.as('endhour')
.keep()
|alert()
.message(message)
// .messageField(message)
result :
... =cpu:nil event_message=" The query period was 10:00 - 12:00 " data="&{cp ...
I get the idea.
One question. I’m using batch and if I use shift function will kapacitor fire two queries?
Hi ,
no , shift will only change the timestamp of the datapoints retrieved ,
