Hello
I would like to display the database size in Openhab2.
what is the path to the windows directory?
with linux the command was:
var String databaseQueryString = executeCommandLine(“sudo du -sh /var/lib/influxdb/data/openhab_db”, 1000)
many thanks
dirk
