I am using InfluxDB 2.0.8 and I would like to check how much disk space each measurement, or bucket uses.
I know how to get the size of entire database:
du -sh ./data/
and apparently in earlier versions of influx there was an “_internal” measurement that could help with getting value for specific measurement, but I don’t see it in influxDB 2.0.8 default internal metrics.
This is part of the default influx metrics found in the main influx bucket, but I can’t find anything helpful here.
Is there any way to achieve what I want? Getting table/measurement disk size seems like a very basic feature that should be available, especially considering it was there in previous influx versions.
