Hi everyone,
I followed the guide from the docs to migrate an influx 1.x instance to the 2.x cloud.
(Upgrade from InfluxDB 1.x to InfluxDB Cloud | InfluxDB Cloud Documentation)
However in the Data Explorer query-builder the measurements are not shown. I did also setup a 1.x connection to the cloud with chronograf, where the data is displayed correctly.
My node application with the 1.x client can query the data correctly, but it seems a bit odd to me as there is no information about the data visible on the cloud dashboard. If you do not know there is data you would think the bucket/database is empty. I also tried the auto upgrade for my local docker deployment, but the result was the same.
So I was wondering if I missed something or if this is the common handling of 1.x data?
Thanks,
Lukas
