Dashboard variable is not getting updated
Im using schema.tagValues to fetch the tag values from the bucket to populate a dashboard variable and i have specified the start parameter to v.timeRangeStart
It does not change when i switch the time range, only when i select the time range and refresh, the dashboard variable gets updated.
Is this is a bug that will get resolved in future updates or am i missing something
@jeyakumar This does sound like a UI bug. Could you submit an issue to the InfluxDB UI repo?
