We are on influx 2.7 and are using the built in Dashboards (transitioned off of Grafana). Our issue is with the font size in the single stat and graph + single stat. The overlay is too busy and difficult to see the numbers but we like the histography in the background because it provides context.
We’re looking for a way to change the font size or other attributes. The main thing is right now the font is too thin to see from a distance.
Anyone know if there is a theme or config file maybe can be modified?
