Hey guys writing a task to downsample data in one of my buckets, got it to work using fluxQL but having issues writing the same query using the java api. Can anyone help with explicitly specifying the start and stop range defined in the query below using the java api?
from(bucket: “test-bucket”)
|> range(start: date.truncate(t: -1d, unit: 1d), stop: date.truncate(t: now(), unit: 1d))
|> filter(fn:(r) => r[“_measurement”] == “SAMPLE”)
|> filter(fn:(r) => r[“_field”] == “count”)
|> sum()
bednar
November 30, 2022, 8:09pm
2
Hi @williamxo ,
there is no direct suport for using truncate in range, but you can define your custom function:
public static class TruncateDateRange extends AbstractParametrizedFlux {
public TruncateDateRange(@Nonnull final Flux source) {
super(source);
addImport("date");
@Nonnull
@Override
protected String operatorName() {
return "range";
@Nonnull
public TruncateDateRange withRange(@Nonnull final String start,
@Nonnull final String stop,
@Nonnull final String unit) {
withPropertyValue("start", String.format("date.truncate(t: %s, unit: 1%s)", start, unit));
withPropertyValue("stop", String.format("date.truncate(t: %s, unit: 1%s)", stop, unit));
return this;
Flux flux = Flux
.from("telegraf")
.function(TruncateDateRange.class)
.withRange("-1d", "now()", "d")
.filter(Restrictions.measurement().equal("SAMPLE"))
.filter(Restrictions.field().equal("count"))
.sum();
System.out.println(flux);
Regards
Hi @bednar , Thanks let me try this out
@bednar Works perfect! thanks for your help.
