Current version of kapacitor and Chronograf
Hi All,
How can i check my current version of Kapacitor and Chronograf ?
Thanks…
hi @ajaypabba ,
you can check it with
kapacitor version ( no dashes )
and
chronograf --version ( 2 dashes )
best regards
Hi Marc,
Thanks for your reply…
Under which path i can get binary files to check versions…
Hi @ajaypabba
it depends how you installed ,
on my linux server they are in /bin ,
best regards
