Hi guys,
I’m struggling trying to get a solution to this: I have a bucket with istant current produced by a PV system and the istant power comsumption for the AC line. I would like to understand how much energy is produced in excess. To do so I did these queries:
solar = from(bucket: “openhab”)
|> filter(fn: (r) => r[“_measurement”] == “SolarRadiation” )
|> aggregateWindow(every: 1h, fn: mean)
|> fill(usePrevious: true)
|> map(fn: (r) => ({r with _field: “Solar”}))
|> map(fn: (r) => ({r with _value: r._value * 0.2048 * .8 * float(v: 44) * 1.78 * 1.09}))
PHA = from(bucket: “openhab”)
|> filter(fn: (r) => r[“_measurement”] == “PHA_Power” )
|> map(fn: (r) => ({r with _field: “PHA_Power”, _value: r._value * -1.0}))
PHB = from(bucket: “openhab”)
|> filter(fn: (r) => r[“_measurement”] == “PHB_Power” )
|> map(fn: (r) => ({r with _field: “PHB_Power”, _value: r._value * -1.0}))
PHC = from(bucket: “openhab”)
|> filter(fn: (r) => r[“_measurement”] == “PHC_Power” )
|> map(fn: (r) => ({r with _field: “PHc_Power”, _value: r._value * -1.0}))
PH_AB = join(tables: {PHA: PHA, PHB: PHB}, on: [“_time”])
PH_ABC = join(tables: {PH_AB: PH_AB, PHC: PHC}, on: [“_time”])
join(tables: {solar: solar, PH_ABC: PH_ABC}, on: [“_time”])
|> map(fn: (r) => ({r with _value: r[“_value_solar”]-(r[“_value_PHA”]+r[“_value_PHB”]+r[“_value_PH_ABC”])}))
|> cumulativeSum()
PHA, PHB, and PHC are the power from the AC line meter (3 phase system), solar is the power produced by the solar panels.
What I need is a sort of cumulativeSum that return 0 if the value is <= 0 or the value in other case.
Does anyone has any idea?
