vinc
July 5, 2021, 6:03pm
1
In Grafana i use a database called test
there is a field called name
and in the name are differnts name like Joe, jane, jack usw. with other information about
i would like to count and get the sum how many time there is a joe, jane and jack int the database
i am able to count
SELECT cumulative_sum(count(“Name”)) FROM “test” WHERE $timeFilter GROUP BY time($__interval) fill(null)
but it just count all!
(count(“Name”)) is there a way to count theme separate
InfluxDB shell version: 1.8.6
have a nice day
vinc
Pooh
July 5, 2021, 6:32pm
2
Try changing “group by time($__interval)” to “group by name,time($__interval)”
Incidentally, is there a reason why you use “cumulative_sum(count(…))”
instead of just “count(…)”? I’m not sure that I see what the sum() is
summing…
Antony.
vinc
July 5, 2021, 6:36pm
3
Hello Antony
thanks for the fast feedback.
in Grafana
i can only choose
group by +
fill(null)
time($interval)
Pooh
July 5, 2021, 6:48pm
4
Go into the Query Editor and you can make the query say whatever you want it
to
Just don’t switch back to the “standard mode” or it’ll throw away your manual
edits…
Antony.
vinc
July 5, 2021, 7:08pm
5
only to use count it count by day if i use the cumulative_sum it add to max sume in the selected time periode.
and to put the name in front of the time, makes no difference
vinc
July 5, 2021, 9:05pm
6
no it is not working, the graph stay empty!
maybe i should not put different node Red output into the same MEASUREMENTS- maybe each output should be put in his own MEASUREMENTS and only in the Graph combined
