Hi, I need to add some meta-data information the source of which is external file. I am using kafka consumer telegraf plugin, so for adding the metadata during run time, I am thinking to use execd plugin, where I would run a python script to get the tags and insert them in kafka data in run time. However, I am not able to get the tags using python script. Below are the files I am using:
- Python script -
import csv
def main():
f = open("meta-data.csv",'r')
csvfile = csv.reader(f)
heading = next(csvfile)
for lines in csvfile:
print(lines[1])
if __name__ == "__main__":
main()
- Telegraf config:
[[inputs.file]]
files = ["input_eg.json"]
data_format = "json"
##other config provided
[[inputs.execd]]
command = ["/usr/bin/python3", "python_code.py"]
data_format = "influx"
Also, can somebody suggest would could be an alternative/better solution for this problem statement?
