Hi all,
I am trying to implement a counter, so that I need to increment the value of the only field in my schema if the record (tag set + timestamp in seconds) already exists, which is often the case. For example, a given tenant sends 3 messages to the same destination within the same second (we are running a SMS Hub)
sms,geo=ES, tenant=101 counter=1 1724258870
My expected result would be
_time _measurement geo tenant counter
2024-08-21T18:47:50Z sms ES 101 3
But I get counter=1 because the tag set and the timestamp is the same.
I want to avoid having to maintain state in the client side to increment the counter before sending it the influx (it would be complex, as the time value is external - coming from mobile operators - and we may get a point for a given timestamp X at X, or a X+any number of seconds - up to 2-3 days)
Query then insert is not an option either, as it will heavily impact the performance of the system and we will not be able to maintain real-time stats (which is the main goal of this project). We are processing tens of thousands of points per second at peak times.
I have read this article, which is exactly the problem I have, but before implementing any of the methods explained here (they all seem a “hack”), I wanted to make sure there is no other way to do it.
Thanks.
