I 'm using inputs.exec to fetch an Ubuntu apt package version number x.x.x. After that i have a inputs.procstat to fetch some data about the executable/process from that apt package.
I would like to add a tag to the inputs.procstat with the version value from the earlier inputs.exec. Is this possible ?
I can’t find any examples or documentation that says how to use processors to reference other inputs data.
Example:
[[inputs.exec]]
commands = [''' /bin/bash -c 'apt info package 2>/dev/null|grep -oP "Version: \K.+"' ''']
[[inputs.procstat]]
exe = "package-executable"
[inputs.procstat.tags]
version = < insert value from inputs.exec >
I was hoping i could set a ENV variable in the inputs.exec and then reference that in the procstat but i don’t think that option is possible.
Thank you.
