Hello, I was wondering if there is a way to use dynamic tag on telegraf, I saw that is easy to do IT use environment variables, but I was trying to find a way to do it like from an script output. Ther is a way to do it ?
It will be possible to do this in the upcoming 1.15.0 release using the execd processor. If you can, it would be very helpful if you could try out the release candidate and let us know if you run into any trouble.
