I am new to InfluxDB. May I know if there’s a way that a new database will be created if the its limit is met. I know a little about RP but is there a way without using RP?
What I’m trying to do is to delete all the data which has retention date of 14 days
If you want to delete all data older than 14 days, then a retention policy is the right way to do that. Could you explain why you would like to do this without using retention policies?
