Hello,I was wondering if there was a way to create an infludb v2 cluster based on docker images . For a school project we need to provide un highly available cluster ( including web ui and database ) the goal would be to have a load balancer as an entry point and a synchronous replication between the different databases . Ideally this cluster / architecture should be scalable . I know that in previous versions of infludb a service called influxdb-relay was available but I did not find any similar tool that was compatible with influx v2 Best regards
HI @moreainflux,
Welcome to the community! Sadly InfluxDB V2 OSS operates as a single node solution. InfluxDB enterprise is our high-availability solution. Is the school project to design a high availability solution or do you just need HA as one of your components for a larger project? Just working out what the best step forward might be to support you.
