Hi there,
I’ve got a point in time dataset including information about how many online shopping slots (count) that are available for different stores (chain, name) per date (YYYY-mm-dd).
I would like to make a bar chart with the stacked counts per day and I’d like to remove the current timestamp (_time) from the table and replace it with a new timestamp compiled using the date. That way I would spread the series out over time again since they are all stacked with the same timestamp (when the measurement was taken).
I’ve managed to get this far:
import “date”
import “strings”
from(bucket: “shopping”)
|> range(start: -5m)
|> filter(fn: ® => r["_measurement"] == “supermarket_slots_history” and r["_field"] =~ /count|day|month/)
|> pivot(rowKey: ["_time"], columnKey: ["_field"], valueColumn: “_value”)
|> filter(fn: ® => r[“month”] == date.month(t: r["_time"]) and r[“day”] > date.monthDay(t: r["_time"]))
|> filter(fn: ® => r[“month”] == date.month(t: r["_time"]) and r[“day”] <= date.monthDay(t: r["_time"])+8)
|> drop(columns: [“host”, “id”, “day”, “daynumberofweek”, “month”, “_measurement”])
|> aggregateWindow(every: 5m, column: “count”, fn: last)
|> set(key: “newtime”, value: “YYYY-mm-ddT00:00:00Z”)
|> group(columns: [“chain”, “name”, “date”])
|> sort(columns: [“date”, “chain”, “name”])
I thought that I could drop the _time column but I would need to create a new timestamp column first and found the set() function. I’m not sure if I can get the date value within that function though? Maybe concatenate my date value with a static ‘T00:00:00Z’ and feed it to the time() function and use that new timestamp as the _time column.
I included the strings library to use strings.joinStr but got stuck.
| #group | FALSE | FALSE | FALSE | FALSE | FALSE | TRUE | TRUE | FALSE | TRUE | FALSE | FALSE |
| #datatype | string | long | dateTime:RFC3339 | dateTime:RFC3339 | dateTime:RFC3339 | string | string | string | string | double | string |
| #default | _result | ||||||||||
| result | table | _time | _start | _stop | chain | date | dayofweek | name | count | newtime | |
| 0 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 14/04/2020 | Tuesday | Regent | 0 | YYYY-mm-ddT00:00:00 | ||
| 1 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 14/04/2020 | Tuesday | Tikipunga | 0 | YYYY-mm-ddT00:00:00 | ||
| 2 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 14/04/2020 | Tuesday | Whangarei | 0 | YYYY-mm-ddT00:00:00 | ||
| 3 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 15/04/2020 | Wednesday | Regent | 0 | YYYY-mm-ddT00:00:00 | ||
| 4 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 15/04/2020 | Wednesday | Tikipunga | 0 | YYYY-mm-ddT00:00:00 | ||
| 5 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 15/04/2020 | Wednesday | Whangarei | 0 | YYYY-mm-ddT00:00:00 | ||
| 6 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 16/04/2020 | Thursday | Regent | 0 | YYYY-mm-ddT00:00:00 | ||
| 7 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 16/04/2020 | Thursday | Tikipunga | 0 | YYYY-mm-ddT00:00:00 | ||
| 8 | 2020-04-13T13:35:00Z | 2020-04-13T13:31:32.804053556Z | 2020-04-13T13:36:32.804053556Z | Countdown | 16/04/2020 | Thursday | Whangarei | 0 | YYYY-mm-ddT00:00:00 |
