I have a couple of measurements in a bucket. Data are collected every day (except on Thursdays and Fridays) from 9 AM to 13 PM, every 1 minute.
Is it possible to store the last daily data of each measurement in a new one? The timestamp of the last data is not always the same, i.e. one day it’s 12:59:30 and another day is 12:58:49.
Without looking in detail I would do the following:
- construct a field my_date containing only the date using map()
- group your data by my_date
- sort by _time in reverse (so the last reading is at the top)
- use |> top(n:1 … to return only the last data for each date
- use |> to() to write it to a bucket
Do you mean something like this?
import "date"
from(bucket: "stocks")
|> range(start: -72h)
|> filter(fn: (r) => r["_measurement"] == "some_name")
|> filter(fn: (r) => r["_field"] == "last")
|> map(
fn: (r) => ({r with
_date: date.truncate(t: r._time, unit: 1d),
_value: r._value,
_name: r._measurement,
|> group(columns: ["_date"])
|> last()
This works great on one measurement. Can we perform this on all measurements in one bucket?
Changing the group solved the problem:
import "date"
|> range(start: -72h)
|> map(
fn: (r) => ({r with
_value: r._value,
|> group(columns: ["_measurement", "_date"])
|> last()
Nice!
Couldn’t have done it better myself!
