Hello.
Is there a way to analyze cost by measurement/tag/field?
We are having a surge in “data in” that leads to high costs, and unable to locate the cause of the problem.
filtering “data in” by measurement or tag will be very helpful.
Thanks.
Hello.
Thanks.
Hello @yuval.schl,
Have you seen the following template?
You can monitor your usage that way.
But it doesn’t look like this template goes into per measurement info:
Thank you.
I’m already monitoring using this dashboard, but it doesn’t help debugging the source of the problem.
This just helps me know that there is a problem.
is there no way to find the measurement that is causing the high costs?
