Hey team, struggling to wrap my head around writing a query to correctly aggregate over space and time.
In this example I am looking at an inventory metric (a point in time metric), and so I the time aggregation needs to be last
. You can see me doing this using aggregateWindow to aggregate my data over time with fn=last. However, as soon as I want to use a group
transformation, last
no longer makes sense. I want it to aggregate last
over time for each series, and then group using a sum
over space. How can I do a group
sum
but an aggregateWindow last
? I’ve attached a screenshot of the my data. Setting group="", should result in a single line of 65.
Hello @Daniel_Langer,
I would imagine that it would result in several tables for each timestamp where aggregateWindow() was applied with:
from(bucket: "system")
|> filter(fn: (r) => r["_measurement"] == "cpu")
|> filter(fn: (r) => r["_field"] == "usage_system" or r["_field"] == "usage_user")
|> filter(fn: (r) => r["cpu"] == "cpu-total")
|> aggregateWindow(every: v.windowPeriod, fn: last, createEmpty: false)
// using limit just to narrow the results and help understand what is happening with the transformation
|> limit(n: 2)
|> group(columns: ["_time"], mode:"by")
|> sum()
Or one table with multiple lines for each timestamp where you applied aggregateWindow:
|> limit(n: 2)
|> schema.fieldsAsCols()
|> map(fn: (r) => ({ r with _value: r.usage_user + r.usage_system }))
Does that help at all?
Thanks.
