I’m trying to select a subset of data as shown below into a new measurement, and then calculate the mean value. The value is treated as a string instead of an integer, eventhough it is inserted as an integer in the original measurement, but I think tags are probably treated as a type of string.
Is it possible to somehow convert (cast) the tag value into an integer?
> select ttr as value, value as ticket into test from ticketdesk
time written
0 10
select * from test limit 3
time ticket value
1550902340000 PE-1234 13132
1550903500000 PE-1238 1022
1550909770000 PE-1245 20433
> select mean(value) from test
ERR: unsupported mean iterator type: *query.stringInterruptIterator
