I am currently attempting to backfill data for a stream tickscript using the method found here: Not possible to record a stream for use with union or join nodes · Issue #925 · influxdata/docs.influxdata.com-ARCHIVE · GitHub
Attempting to create the recording generates the following error however:
Post http://localhost:9092/kapacitor/v1/recordings/query: read tcp [::1]:59814->[::1]:9092: read: connection reset by peer
I’m pretty sure this isn’t a firewall issue as I am able to telnet to 9092 on the machine
here’s my Kapacitor config for reference
# The hostname of this node.
# Must be resolvable by any configured InfluxDB hosts.
hostname = "localhost"
# Directory for storing a small amount of metadata about the server.
data_dir = "/var/lib/kapacitor"
# Do not apply configuration overrides during startup.
# Useful if the configuration overrides cause Kapacitor to fail startup.
# This option is intended as a safe guard and should not be needed in practice.
skip-config-overrides = false
# Default retention-policy, if a write is made to Kapacitor and
# it does not have a retention policy associated with it,
# then the retention policy will be set to this value
default-retention-policy = ""
[http]
# HTTP API Server for Kapacitor
# This server is always on,
# it serves both as a write endpoint
# and as the API endpoint for all other
# Kapacitor calls.
bind-address = ":9092"
auth-enabled = false
log-enabled = true
write-tracing = false
pprof-enabled = false
https-enabled = false
https-certificate = "/etc/ssl/kapacitor.pem"
[config-override]
# Enable/Disable the service for overridding configuration via the HTTP API.
enabled = true
[logging]
# Destination for logs
# Can be a path to a file or 'STDOUT', 'STDERR'.
file = "/var/log/kapacitor/kapacitor.log"
# Logging level can be one of:
# DEBUG, INFO, WARN, ERROR, or OFF
level = "INFO"
[replay]
# Where to store replay files, aka recordings.
dir = "/var/lib/kapacitor/replay"
[task]
# Where to store the tasks database
# DEPRECATED: This option is not needed for new installations.
# It is only used to determine the location of the task.db file
# for migrating to the new `storage` service.
dir = "/var/lib/kapacitor/tasks"
# How often to snapshot running task state.
snapshot-interval = "60s"
[storage]
# Where to store the Kapacitor boltdb database
boltdb = "/var/lib/kapacitor/kapacitor.db"
[deadman]
# Configure a deadman's switch
# Globally configure deadman's switches on all tasks.
# NOTE: for this to be of use you must also globally configure at least one alerting method.
global = false
# Threshold, if globally configured the alert will be triggered if the throughput in points/interval is <= threshold.
threshold = 0.0
# Interval, if globally configured the frequency at which to check the throughput.
interval = "10s"
# Id -- the alert Id, NODE_NAME will be replaced with the name of the node being monitored.
id = "node 'NODE_NAME' in task '{{ .TaskName }}'"
# The message of the alert. INTERVAL will be replaced by the interval.
message = "{{ .ID }} is {{ if eq .Level \"OK\" }}alive{{ else }}dead{{ end }}: {{ index .Fields \"collected\" | printf \"%0.3f\" }} points/INTERVAL."
# Multiple InfluxDB configurations can be defined.
# Exactly one must be marked as the default.
# Each one will be given a name and can be referenced in batch queries and InfluxDBOut nodes.
[[influxdb]]
# Connect to an InfluxDB cluster
# Kapacitor can subscribe, query and write to this cluster.
# Using InfluxDB is not required and can be disabled.
enabled = true
default = true
name = "localhost"
urls = ["https://localhost:8086"]
username = "kapacitor"
password = "<snip>"
timeout = 0
# Absolute path to pem encoded CA file.
# A CA can be provided without a key/cert pair
# ssl-ca = "/etc/kapacitor/ca.pem"
# Absolutes paths to pem encoded key and cert files.
# ssl-cert = "/etc/kapacitor/cert.pem"
# ssl-key = "/etc/kapacitor/key.pem"
# Do not verify the TLS/SSL certificate.
# This is insecure.
insecure-skip-verify = true
# Maximum time to try and connect to InfluxDB during startup
startup-timeout = "5m"
# Turn off all subscriptions
disable-subscriptions = false
# Which protocol to use for subscriptions
# one of 'udp', 'http', or 'https'.
subscription-protocol = "http"
# Subscriptions resync time interval
# Useful if you want to subscribe to new created databases
# without restart Kapacitord
subscriptions-sync-interval = "1m0s"
# Override the global hostname option for this InfluxDB cluster.
# Useful if the InfluxDB cluster is in a separate network and
# needs special config to connect back to this Kapacitor instance.
# Defaults to `hostname` if empty.
kapacitor-hostname = ""
# Override the global http port option for this InfluxDB cluster.
# Defaults to the port from `[http] bind-address` if 0.
http-port = 0
# Host part of a bind address for UDP listeners.
# For example if a UDP listener is using port 1234
# and `udp-bind = "hostname_or_ip"`,
# then the UDP port will be bound to `hostname_or_ip:1234`
# The default empty value will bind to all addresses.
udp-bind = ""
# Subscriptions use the UDP network protocl.
# The following options of for the created UDP listeners for each subscription.
# Number of packets to buffer when reading packets off the socket.
udp-buffer = 1000
# The size in bytes of the OS read buffer for the UDP socket.
# A value of 0 indicates use the OS default.
udp-read-buffer = 0
[influxdb.subscriptions]
# Set of databases and retention policies to subscribe to.
# If empty will subscribe to all, minus the list in
# influxdb.excluded-subscriptions
# Format
# db_name = <list of retention policies>
# Example:
# my_database = [ "default", "longterm" ]
[influxdb.excluded-subscriptions]
# Set of databases and retention policies to exclude from the subscriptions.
# If influxdb.subscriptions is empty it will subscribe to all
# except databases listed here.
# Format
# Example:
[kubernetes]
# Enable/Disable the kubernetes service.
# Needed by the k8sAutoscale TICKscript node.
enabled = false
# There are several ways to connect to the kubernetes API servers:
# Via the proxy, start the proxy via the `kubectl proxy` command:
# api-servers = ["http://localhost:8001"]
# From within the cluster itself, in which case
# kubernetes secrets and DNS services are used
# to determine the needed configuration.
# in-cluster = true
# Direct connection, in which case you need to know
# the URL of the API servers, the authentication token and
# the path to the ca cert bundle.
# These value can be found using the `kubectl config view` command.
# api-servers = ["http://192.168.99.100:8443"]
# token = "..."
# ca-path = "/path/to/kubernetes/ca.crt"
[smtp]
# Configure an SMTP email server
# Will use TLS and authentication if possible
# Only necessary for sending emails from alerts.
enabled = false
host = "localhost"
port = 25
username = ""
password = ""
# From address for outgoing mail
from = ""
# List of default To addresses.
# to = ["oncall@example.com"]
# Skip TLS certificate verify when connecting to SMTP server
no-verify = false
# Close idle connections after timeout
idle-timeout = "30s"
# If true the all alerts will be sent via Email
# without explicitly marking them in the TICKscript.
global = false
# Only applies if global is true.
# Sets all alerts in state-changes-only mode,
# meaning alerts will only be sent if the alert state changes.
state-changes-only = false
[snmptrap]
# Configure an SNMP trap server
enabled = false
# The host:port address of the SNMP trap server
addr = "localhost:162"
# The community to use for traps
community = "kapacitor"
# Number of retries when sending traps
retries = 1
[opsgenie]
# Configure OpsGenie with your API key and default routing key.
enabled = false
# Your OpsGenie API Key.
api-key = ""
# Default OpsGenie teams, can be overridden per alert.
# teams = ["team1", "team2"]
# Default OpsGenie recipients, can be overridden per alert.
# recipients = ["recipient1", "recipient2"]
# The OpsGenie API URL should not need to be changed.
url = "https://api.opsgenie.com/v1/json/alert"
# The OpsGenie Recovery URL, you can change this
# based on which behavior you want a recovery to
# trigger (Add Notes, Close Alert, etc.)
recovery_url = "https://api.opsgenie.com/v1/json/alert/note"
# If true then all alerts will be sent to OpsGenie
# The team and recipients can still be overridden.
global = false
[victorops]
# Configure VictorOps with your API key and default routing key.
enabled = false
# Your VictorOps API Key.
api-key = ""
# Default VictorOps routing key, can be overridden per alert.
routing-key = ""
# The VictorOps API URL should not need to be changed.
url = "https://alert.victorops.com/integrations/generic/20131114/alert"
# If true the all alerts will be sent to VictorOps
# The routing key can still be overridden.
global = false
[pagerduty]
# Configure PagerDuty.
enabled = false
# Your PagerDuty Service Key.
service-key = ""
# The PagerDuty API URL should not need to be changed.
url = "https://events.pagerduty.com/generic/2010-04-15/create_event.json"
# If true the all alerts will be sent to PagerDuty
global = false
[slack]
# Configure Slack.
enabled = false
# The Slack webhook URL, can be obtained by adding
# an Incoming Webhook integration.
# Visit https://slack.com/services/new/incoming-webhook
# to add new webhook for Kapacitor.
url = ""
# Default channel for messages
channel = ""
# If true all the alerts will be sent to Slack
global = false
[telegram]
# Configure Telegram.
enabled = false
# The Telegram Bot URL should not need to be changed.
url = "https://api.telegram.org/bot"
# Telegram Bot Token, can be obtained From @BotFather.
token = ""
# Default recipient for messages, Contact @myidbot on Telegram to get an ID.
chat-id = ""
# Send Markdown or HTML, if you want Telegram apps to show bold, italic, fixed-width text or inline URLs in your alert message.
#parse-mode = "Markdown"
# Disable link previews for links in this message
disable-web-page-preview = false
# Sends the message silently. iOS users will not receive a notification, Android users will receive a notification with no sound.
disable-notification = false
# If true the all alerts will be sent to Telegram
global = false
[hipchat]
# Configure HipChat.
enabled = false
# The HipChat API URL. Replace subdomain with your
# HipChat subdomain.
url = "https://subdomain.hipchat.com/v2/room"
# Visit https://www.hipchat.com/docs/apiv2
# for information on obtaining your room id and
# authentication token.
# Default room for messages
room = ""
# Default authentication token
token = ""
# If true then all alerts will be sent to HipChat
global = false
[alerta]
# Configure Alerta.
enabled = false
# The Alerta URL.
url = ""
# Default authentication token.
token = ""
# Default environment.
environment = ""
# Default origin.
origin = "kapacitor"
[sensu]
# Configure Sensu.
enabled = false
# The Sensu Client host:port address.
addr = "sensu-client:3030"
# Default JIT source.
source = "Kapacitor"
[reporting]
# Send usage statistics
# every 12 hours to Enterprise.
enabled = true
url = "https://usage.influxdata.com"
[stats]
# Emit internal statistics about Kapacitor.
# To consume these stats create a stream task
# that selects data from the configured database
# and retention policy.
# Example:
# stream.from().database('_kapacitor').retentionPolicy('default')...
enabled = true
stats-interval = "10s"
database = "_kapacitor"
retention-policy= "autogen"
[udf]
# Configuration for UDFs (User Defined Functions)
[udf.functions]
# Example go UDF.
# First compile example:
# go build -o avg_udf ./udf/agent/examples/moving_avg.go
# Use in TICKscript like:
# stream.goavg()
# .field('value')
# .size(10)
# .as('m_average')
# uncomment to enable
#[udf.functions.goavg]
# prog = "./avg_udf"
# args = []
# timeout = "10s"
# Example python UDF.
# stream.pyavg()
# .field('value')
# .size(10)
# .as('m_average')
#[udf.functions.pyavg]
# prog = "/usr/bin/python2"
# args = ["-u", "./udf/agent/examples/moving_avg.py"]
# timeout = "10s"
# [udf.functions.pyavg.env]
# PYTHONPATH = "./udf/agent/py"
# Example UDF over a socket
#[udf.functions.myCustomUDF]
# socket = "/path/to/socket"
# timeout = "10s"
[talk]
# Configure Talk.
enabled = false
# The Talk webhook URL.
url = "https://jianliao.com/v2/services/webhook/uuid"
# The default authorName.
author_name = "Kapacitor"
# Input Methods, same as InfluxDB
[collectd]
enabled = false
bind-address = ":25826"
database = "collectd"
batch-size = 1000
batch-pending = 5
batch-timeout = "10s"
typesdb = "/usr/share/collectd/types.db"
[opentsdb]
enabled = false
bind-address = ":4242"
database = "opentsdb"
consistency-level = "one"
tls-enabled = false
certificate = "/etc/ssl/influxdb.pem"
batch-size = 1000
batch-pending = 5
batch-timeout = "1s"
