Hi all,
Is there a trick I could use to compute an average cycle time from a series that simply captures the state (on/off) of a boiler?
I know this is possible using flux and monitor.stateChanges, but I have a pure influxql Grafana setup for now and I would rather avoid migrating while I can…
For this series:
0 0 1 1 0 1 0
where points are logged every mn the result should be 90s (one 2mn cycle and one 1mn cycle).
Thanks!
Maybe I will have more success with this
I have been trying my first flux query, and I am getting pretty close but I can’t figure out how to wrap things up:
The data has a single “pe_isburning” column with a value of 0 or 1 indicating whether a boiler is running. I am trying to compute the average cycle time in a given time window.
This query :
import "influxdata/influxdb/monitor"
from(bucket: "pellematic/autogen")
|> filter(fn: (r) => r._field == "pe_isburning")
|> toString()
|> rename(columns: {_value: "_level"})
|> stateDuration(fn: (r) => r._level == "1")
|> yield()
yields
2022-10-12 08:56:10. 1 1260
2022-10-12 08:57:10. 1 1320
2022-10-12 08:58:10 1 1380
2022-10-12 08:59:10. 0 -1
… and my intention was to follow up with monitor.stateChanges(…) to pick up the “1380” record… however stateChanges picks up the first records of each state; the total I am looking for is in the last record for each state… any suggestion?
[Note: the toString is there because stateChanges seems to require a string value]
