I need to get difference from recorder (1001,1002,1003,1004…) and recorder 535, i.e:
I wrote this query:
from(bucket:"sensoring")
|> range(start:-1h)
|> filter(fn:(r) => r._measurement == "readings" and r._field == "value" and r.recorder == "535" or r.recorder == "1001")
|> limit(n:5, offset: 0)
And got this:
#group | FALSE | FALSE | TRUE | TRUE | FALSE | FALSE | TRUE | TRUE | TRUE |
#datatype | string | long | dateTime:RFC3339 | dateTime:RFC3339 | dateTime:RFC3339 | double | string | string | string |
#default | _result | ||||||||
result | table | _start | _stop | _time | _value | _field | _measurement | recorder | |
0 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:32.369Z | 431 | value | readings | 1001 | ||
0 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:34.015Z | 430 | value | readings | 1001 | ||
0 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:35.375Z | 431 | value | readings | 1001 | ||
0 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:44.375Z | 432 | value | readings | 1001 | ||
0 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:49.04Z | 431 | value | readings | 1001 | ||
1 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:21.806Z | 429 | value | readings | 535 | ||
1 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:23.284Z | 429 | value | readings | 535 | ||
1 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:24.768Z | 429 | value | readings | 535 | ||
1 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:26.286Z | 429 | value | readings | 535 | ||
1 | 2021-09-03T19:17:20.869852374Z | 2021-09-03T20:17:20.869852374Z | 2021-09-03T19:17:27.793Z | 429 | value | readings | 535 |
How can I compare data from table 1 and 2 and get values like: 2, 1, 2, 3, 2…?
I did this to one recorder, but how can i put recorder “535” dinamically as setpoint on map function:
|> range(start:-1h)
|> filter(fn:(r) => r._measurement == "readings" and r._field == "value" and r.recorder == "1001")
|> map(fn: (r) => ({r with diff: r._value - 50.0}))
I tried this: Use multiple fields in a calculation | InfluxDB Cloud Documentation (influxdata.com)
But wasn’t helpful.
Thankou for your help.
