Difference between counts
I tried to use difference() to find the offset between current & previous counts but seems not working properly.
from(bucket: "Dialout")
  |> range(start: -30s, stop: v.timeRangeStop)
  |> filter(fn: (r) => r["_measurement"] == "show interface status")
  |> filter(fn: (r) => r["source"] == "device")
  |> filter(fn: (r) => r["_field"] == "state")
  |> filter(fn: (r) => r["_value"] == "connected")
  |> last()
  |> unique(column: "TABLE_interface")
  |> group(columns: ["host", "_measurement"], mode:"by")
  |> count()
  |> difference(nonNegative: false, columns: ["_value"])
Can someone give me a hint?
Regards,
Minh
Welcome @mdang
Can you clarify what you mean by “previous count”? The count of your value 30 seconds ago?
I presume that “current count” means the count of the most recent values in the database?
Thanks for looking into this.
Correct. My goal is to get the diff between the most recent count vs 30s ago in the database.
I think a union will be needed. Something like this…
FirstPeriod1 = from(bucket: "Dialout")
  |> range(start: -31s, stop: now())
  |> last()
  |> count()
  |> set(key: "newValue", value: "first_value_of_period1")
  |> yield(name: "first_period1")
 LastPeriod1 = from(bucket: "Dialout")
  |> range(start: -60s, stop: -30s)
  |> last()
  |> count()
  |> set(key: "newValue", value: "last_value_of__period1")
  |> yield(name: "last_period1")
Period1_Union = union(tables: [FirstPeriod1, LastPeriod1])
  |> pivot(rowKey:["_time"], columnKey: ["newValue"], valueColumn: "_value")
  |> map(fn: (r) => ({ r with period1_difference: r.last_value_of_period1 - r.first_value_of_period1 }))
  |> yield(name: "Period1_Union")
