Hello, everyone! First poster here.
I’m using the Jenkins InfluxDB plugin to store metrics about my Jenkins instance and I’m trying to plot them using Grafana.
I want to combine two measurements and have one as the X axis of a bar chart, and the other as the Y chart.
In the following example, I want to have the build_number as the X axis and the build_time measurement as the Y axis.
What’s the best way to achieve this result? I’ve tried using the join() function, but I didn’t get the results I was expecting.
_start:time _stop:time _field:string _measurement:string build_result:string instance:string project_name:string project_namespace:string project_path:string _time:time _value:int
2023-12-11T17:35:31.101733947Z 2023-12-12T17:35:31.101733947Z build_number jenkins_data FAILURE *** InfluxDB Test Test_folder Test_folder/InfluxDB Test 2023-12-12T13:31:58.113000000Z 14
2023-12-11T17:35:31.101733947Z 2023-12-12T17:35:31.101733947Z build_time jenkins_data FAILURE *** InfluxDB Test Test_folder Test_folder/InfluxDB Test 2023-12-12T13:31:58.113000000Z 1784
Essentially I’m trying to convert this dashboard (Jenkins Build Status | Grafana Labs) to Flux and to the new InfluxDB plugin version.
Thanks in advance.
