Hi!
Is there a way or an input plugin for Telegraf to collect the following info on the host? Essentially want anything that’s part of the /etc/lsb-release
file.
- DISTRIB_ID
- OS version
- Code Name
- OS Family
- Kernal
- Mac Address
Hi!
file.
There is no input plugin to my knowledge that would collect all of these datapoints out of the box. What I would suggest you use is the exec
plugin to collect the specific metrics and datapoints you want as a script and then telegraf can run that script and send it to whatever outputs you want.
Kernel
Mac Address
These won’t be in /etc/lsb-release
, but with a self-written script, you can collect any and all the points you are after!
