I have a home automation system that pushes out sensor data and collectd data to a windows 10 server running influxdb.
The sensodata is collected, but i can’t get collectd to work!
Any hints/clues? I saw a stdout from someone else that had “starting collectd service” in there…
influxdb.conf:
[collectd]
enabled = true
bind-address = ":25826"
database = "collectd"
typesdb = "C:\Huset - Instrumenteringslogg\influxdb-1.7.8-1\types.db"
batch-size = 5000
batch-pending = 10
batch-timeout = "10s"
read-buffer = 0
stdout from starting influxdb:
ts=2019-11-02T02:07:15.636354Z lvl=info msg=“InfluxDB starting” log_id=0IrThzi0000 version=1.7.8 branch=1.7 commit=ff383cdc0420217e3460dabe17db54f8557d95b6
ts=2019-11-02T02:07:15.637353Z lvl=info msg=“Go runtime” log_id=0IrThzi0000 version=go1.11 maxprocs=4
ts=2019-11-02T02:07:15.739355Z lvl=info msg=“Using data dir” log_id=0IrThzi0000 service=store path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data
ts=2019-11-02T02:07:15.739355Z lvl=info msg=“Compaction settings” log_id=0IrThzi0000 service=store max_concurrent_compactions=2 throughput_bytes_per_second=50331648 throughput_bytes_per_second_burst=50331648
ts=2019-11-02T02:07:15.739355Z lvl=info msg=“Open store (start)” log_id=0IrThzi0000 service=store trace_id=0IrTh~6l000 op_name=tsdb_open op_event=start
ts=2019-11-02T02:07:15.749370Z lvl=info msg=“Reading file” log_id=0IrThzi0000 engine=tsm1 service=cacheloader path=C:\WINDOWS\system32\config\systemprofile\.influxdb\wal\_internal\monitor\3\_00001.wal size=3940223
ts=2019-11-02T02:07:15.749370Z lvl=info msg=“Opened file” log_id=0IrThzi0000 engine=tsm1 service=filestore path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data\_internal\monitor\1\000000005-000000001.tsm id=2 duration=1.012ms
ts=2019-11-02T02:07:15.749370Z lvl=info msg=“Opened file” log_id=0IrThzi0000 engine=tsm1 service=filestore path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data\_internal\monitor\1\000000001-000000001.tsm id=0 duration=0.000ms
ts=2019-11-02T02:07:15.754364Z lvl=info msg=“Opened file” log_id=0IrThzi0000 engine=tsm1 service=filestore path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data\_internal\monitor\1\000000003-000000001.tsm id=1 duration=4.994ms
ts=2019-11-02T02:07:15.755369Z lvl=info msg=“Reading file” log_id=0IrThzi0000 engine=tsm1 service=cacheloader path=C:\WINDOWS\system32\config\systemprofile\.influxdb\wal\_internal\monitor\1\_00001.wal size=200032
ts=2019-11-02T02:07:15.762362Z lvl=info msg=“Reading file” log_id=0IrThzi0000 engine=tsm1 service=cacheloader path=C:\WINDOWS\system32\config\systemprofile\.influxdb\wal\vera\autogen\2\_00001.wal size=1878339
ts=2019-11-02T02:07:15.797997Z lvl=info msg=“Opened shard” log_id=0IrThzi0000 service=store trace_id=0IrTh~6l000 op_name=tsdb_open index_version=inmem path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data\_internal\monitor\1 duration=51.642ms
ts=2019-11-02T02:07:15.924749Z lvl=info msg=“Opened shard” log_id=0IrThzi0000 service=store trace_id=0IrTh~6l000 op_name=tsdb_open index_version=inmem path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data\vera\autogen\2 duration=169.379ms
ts=2019-11-02T02:07:16.210930Z lvl=info msg=“Opened shard” log_id=0IrThzi0000 service=store trace_id=0IrTh~6l000 op_name=tsdb_open index_version=inmem path=C:\WINDOWS\system32\config\systemprofile\.influxdb\data\_internal\monitor\3 duration=464.576ms
ts=2019-11-02T02:07:16.210930Z lvl=info msg=“Open store (end)” log_id=0IrThzi0000 service=store trace_id=0IrTh~6l000 op_name=tsdb_open op_event=end op_elapsed=471.575ms
ts=2019-11-02T02:07:16.210930Z lvl=info msg=“Opened service” log_id=0IrThzi0000 service=subscriber
ts=2019-11-02T02:07:16.210930Z lvl=info msg=“Starting monitor service” log_id=0IrThzi0000 service=monitor
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Registered diagnostics client” log_id=0IrThzi0000 service=monitor name=build
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Registered diagnostics client” log_id=0IrThzi0000 service=monitor name=runtime
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Registered diagnostics client” log_id=0IrThzi0000 service=monitor name=network
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Registered diagnostics client” log_id=0IrThzi0000 service=monitor name=system
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Starting precreation service” log_id=0IrThzi0000 service=shard-precreation check_interval=10m advance_period=30m
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Starting snapshot service” log_id=0IrThzi0000 service=snapshot
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Starting continuous query service” log_id=0IrThzi0000 service=continuous_querier
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“Starting HTTP service” log_id=0IrThzi0000 service=httpd authentication=false
ts=2019-11-02T02:07:16.211942Z lvl=info msg=“opened HTTP access log” log_id=0IrThzi0000 service=httpd path=stderr
ts=2019-11-02T02:07:16.212930Z lvl=info msg=“Listening on HTTP” log_id=0IrThzi0000 service=httpd addr=[::]:8086 https=false
ts=2019-11-02T02:07:16.212930Z lvl=info msg=“Starting retention policy enforcement service” log_id=0IrThzi0000 service=retention check_interval=30m
ts=2019-11-02T02:07:16.212930Z lvl=info msg=“Listening for signals” log_id=0IrThzi0000
ts=2019-11-02T02:07:16.213929Z lvl=info msg=“Storing statistics” log_id=0IrThzi0000 service=monitor db_instance=_internal db_rp=monitor interval=10s
ts=2019-11-02T02:07:16.214938Z lvl=info msg=“Sending usage statistics to usage.influxdata.com” log_id=0IrThzi0000
