Chronograf visualization in microseconds resolution
How can we build a visualization for time series data which is in microseconds resolution?
  1. InfluxDB seems to support nanoseconds resolution (RFC3339 format e.g., YYYY-MM-DDTHH:MM:SS.nnnnnnnnnZ)
  2. Chronograf (1.7.5) and Grafana (5.4.2) seem to support only milliseconds resolution. Correct?
Any concrete suggestion, pointer to another tool or an idea is welcomed.
Thanks in advance!
Both Chronograf and Grafana currently only support millisecond resolution, that is correct.
In terms of building your own visualizations, one of our former developer advocates wrote a number of posts about visualizing data from InfluxDB with various visualization libraries that could help you get started. Here are some links:
