We currently use Grafana to display data from influxDB.
The env gets populated based on timeframe selected in dashboard. The Jobname is dependent on Env selected and the build on Jobname.
How do I implement similar behavior in Chronograf?
I added the following template variable for Env
Jobname shows all values if I use the meta query,
How do I create a custom metaquery to fetch jobname values for selected Env?
Thanks,
Shruthi
