I am using chronograf dashboard for showing custom graphs at runtime. For that I have used template variable so it take value dynamically. But when I try to pass the template variable in URL it is not working.Is there any way I can achieve this.
I think what you are trying to achieve is currently a feature in progress, as referenced in this thread. It should be available very soon.
