Chronograf not working behind reverse proxy
I am trying to run chronograf behind a reverse proxy and I am failing.
I did use various combination settings of basepath and publicurl but nothing seems to properly work.
I am using chronograf from the chronograf-1.7.14.x86_64.rpm
What am I doing wrong?
TIA
Hendrik
I’m facing the same issues
I suspect there’s a problem with the way you have set up the reverse proxy.
However, unless you tell us the detail of how you’ve set it up, we have no way
to know which bit might not be correct.
Antony.
Sorry, I’m not running chronograph behind nginx proxy.
I’m accessing influxdb databases behind an nginx proxy in the chronograph web portal. But getting issue. I can connect this nginx proxy database in “Time series admin” software.
