Hello all, im new to TICK stack, im currently trying to run TICK on Centos and im having an issue running Chronograf.
Chronograf Version 1.4.3.1
The issue im having is i have a port already using :8888, so i changed my “Chronograf config” /usr/lib/systemd/system/chronograf.service to listen on 8889 " Environment=‘PORT=8889’ " instead and also changed the init.sh as well, i then restarted the service.
This is the error im getting when i try running chronograf.
ERRO[0000] listen tcp 0.0.0.0:8888: bind: address already in use component=server
yyyy/mm/dd hh:mm:ss listen tcp 0.0.0.0:8888: bind: address already in use
Which is what i was trying to resolve, am i missing something.
Thanks in advance.
