Can't write datas in other disk
Hello !
First time creating a post in a forum for a question like this, and as a non-native english speaker, i’ll try to make it as clear as possible !
I installed InfluxDB3 on a VM, and the VM has a second disk mounted on it, XFS filesystem, on a specific VG (vg2-data), mounted as /data.
In my influxdb3-core.conf, I changed the field “data-dir” to “/data/influxdb3”, created the folder /data/influxdb3 and restarted my influx-db3-core service.
Here’s the thing… influxdb3-core service can’t start, status “failed”, logs telling me “Read-Only Filesystem” (while filesystem isn’t read-only)… What I tried :
  • Setting /data to 777 and everything under it to allow influxdb3-core service to create it’s folders → Not working
  • Setting the user influxdb3 as owner of /data → not working
  • Removing noexec to my fstab for the /data folder → not working
I installed InfluxDB2 instead, and it worked out of the box, writing everything inside /data.
Any tips ?
Thanks for any answers !
Fixed :
In /usr/lib/systemd/system/influxdb3-core.service you need to add a ReadWritePaths= to allow the service to write in it.
Thanks! That worked for me also.
The exact error and InfluxDB version are needed to narrow this down. Please include the configured data path, how InfluxDB is installed (Docker or system service), and whether the service account can write to the mounted disk. For Docker, also check that the host directory is mounted at the container’s configured data path and isn’t read-only.
