Hi
When i create new bucket i can set retention for “Never”, but if i change it e.g. to 1y, then i can’t set it back for never - why or how fix it ?
Hi
I have the same problem, any suggestions/solutions?
Greetings
@lakusz1influx @Chriz you can update the retention to “infinite” using the influx CLI:
influx bucket update -i <your-bucket-id> --retention 0
Thy so much, that did it
I had the same issue but the command line command fixed it. Is there some reason though why the UI cannot do it? This is a rather obvious bug.
Same here, for the books, I’m using:
InfluxDB v2.6.0
Server: 24a2b62
Frontend: cbab7db
This is a open issue since almost two years … assuming there is no intention to fix it!?
I just changed the retention time to 99 years in the GUI. I think thats long enough ![]()
