I’ve written a python script that requests a vrealizeops API and retrieves the response in JSON.
First of all, before going any further, because of the security measures in place in my company, the VM I’m currently working on doesn’t have the ports open to update telegraf from the repositories, the version I have doesn’t have the json_v2 parser…
So I’m recovering this input:
"viewsData": [
"rows": [
"cells": {
"objUUID": "2cf65c5b-58d3-4962-8bdf-9cca87897586",
"grandTotal": false,
"groupUUID": null,
"summary": false,
"1": 1693785600000,
"3": 495440.0,
"2": 28.15151596069336,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1694390400000,
"3": 501264.0,
"2": 27.820512771606445,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1694995200000,
"3": 502272.0,
"2": 26.972028732299805,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1695600000000,
"3": 507136.0,
"2": 26.82517433166504,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1696204800000,
"3": 508384.0,
"2": 26.11655044555664,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1696809600000,
"3": 510128.0,
"2": 25.93473243713379,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1697414400000,
"3": 513584.0,
"2": 25.680652618408203,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1698019200000,
"3": 520144.0,
"2": 25.177156448364258,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1698624000000,
"3": 522368.0,
"2": 24.221445083618164,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1699228800000,
"3": 525240.0,
"2": 23.897436141967773,
"4": 686400.0,
"objId": "hp-3par"
"cells": {
"groupUUID": null,
"summary": false,
"1": 1699833600000,
"3": 525304.0,
"2": 23.479021072387695,
"4": 686400.0,
"objId": "hp-3par"
"name": "hp3par",
"startTime": 1693859599104,
"endTime": 1699907599104,
"type": "list-view",
"columns": [
"unit": null,
"key": "objId",
"label": "Name"
"unit": null,
"key": "1",
"label": "week"
"unit": "%",
"key": "2",
"label": "Free scape (%)"
"unit": null,
"key": "3",
"label": "used capacity(GiB)"
"unit": null,
"key": "4",
"label": "Total capacity (GiB)"
"unit": null,
"key": "summary",
"label": "Summary"
"unit": null,
"key": "grandTotal",
"label": "Grand Total"
"unit": null,
"key": "groupUUID",
"label": "Group UUID"
"unit": null,
"key": "objUUID",
"label": "Object UUID"
"description": ""
So far the only output I can retrieve at best is this:
viewsData_0_description="",
viewsData_0_endTime=1699907309072,
viewsData_0_name="hp3par",
viewsData_0_rows_0_cells_1=1693785600000,
viewsData_0_rows_0_cells_2=28.15151596069336,
viewsData_0_rows_0_cells_3=495440,
viewsData_0_rows_0_cells_4=686400,
viewsData_0_rows_10_cells_1=1699833600000,
viewsData_0_rows_10_cells_2=23.479021072387695,
viewsData_0_rows_10_cells_3=525304,
viewsData_0_rows_10_cells_4=686400,
viewsData_0_rows_1_cells_1=1694390400000,
viewsData_0_rows_1_cells_2=27.820512771606445,
viewsData_0_rows_1_cells_3=501264,
viewsData_0_rows_1_cells_4=686400,
viewsData_0_rows_2_cells_1=1694995200000,
viewsData_0_rows_2_cells_2=26.972028732299805,
viewsData_0_rows_2_cells_3=502272,
viewsData_0_rows_2_cells_4=686400,
viewsData_0_rows_3_cells_1=1695600000000,
viewsData_0_rows_3_cells_2=26.82517433166504,
viewsData_0_rows_3_cells_3=507136,
viewsData_0_rows_3_cells_4=686400,
viewsData_0_rows_4_cells_1=1696204800000,
viewsData_0_rows_4_cells_2=26.11655044555664,
viewsData_0_rows_4_cells_3=508384,
viewsData_0_rows_4_cells_4=686400,
viewsData_0_rows_5_cells_1=1696809600000,
viewsData_0_rows_5_cells_2=25.93473243713379,
viewsData_0_rows_5_cells_3=510128,
viewsData_0_rows_5_cells_4=686400,
viewsData_0_rows_6_cells_1=1697414400000,
viewsData_0_rows_6_cells_2=25.680652618408203,
viewsData_0_rows_6_cells_3=513584,
viewsData_0_rows_6_cells_4=686400,
viewsData_0_rows_7_cells_1=1698019200000,
viewsData_0_rows_7_cells_2=25.177156448364258,
viewsData_0_rows_7_cells_3=520144,
viewsData_0_rows_7_cells_4=686400,
viewsData_0_rows_8_cells_1=1698624000000,
viewsData_0_rows_8_cells_2=24.221445083618164,
viewsData_0_rows_8_cells_3=522368,
viewsData_0_rows_8_cells_4=686400,
viewsData_0_rows_9_cells_1=1699228800000,
viewsData_0_rows_9_cells_2=23.897436141967773,
viewsData_0_rows_9_cells_3=525240,
viewsData_0_rows_9_cells_4=686400,
viewsData_0_type="list-view" 1693859309000000000
With this config:
[[inputs.exec]]
## Commands array
commands = ["/etc/telegraf/scripts/get_views_vrops.py"]
## Timeout for each command to complete.
timeout = "120s"
interval = "86400s"
name_override = "Get_vROps_storage_views"
data_format = "json"
json_time_key = "viewsData_0_startTime"
json_time_format = "unix_ms"
json_name_key = "viewsData_0_startTime"
json_string_fields = ["viewsData_0_name", "viewsData_0_description", "viewsData_0_type"]
My questions are:
1/ Why does it manage to retrieve the “rows” array but not the “columns” array?
2/ The “rows” and “columns” arrays are never of a fixed size, so how can I, for example, retrieve the “objId” fields found in all the “cells” of the “rows” array?
Thank you in advance for your answers !
Best regards
