I’m using telegraf to parse log files with the inputs.tail plugin and some grok patterns.
I noticed that I could process the logs when they were encoded as UTF8, but grok doesn’t find my matches when the logs are encoded as ANSI.
For the moment, I don’t consider changing the logs encoding to UTF8 externally. Is there any way to parse them as ANSI directly ? If it’s not possible, is there a way to preprocess the logs before calling inputs.tail ? I would eventually be able to call a Powershell script to convert the lines to UTF8, but I’m not sure if it’s the way to go.
Any hints would be appreciated ! Thanks
