Hello there
I just joined and started the tutorial provided by the @discobot.
The first “normal” tutorial has no problem.
But if you start the “advanced tutorial” you can NEVER finish it
Quote from @discobot
Awesome work! I hope you didn’t mute this topic since I can be a little talkative at times :grin:.
Note that when you reply to a topic, or read a topic for more than a few minutes, it is automatically set to a notification level of ‘tracking’. You can change this in your user preferences.
Did you know you can add a poll to any post? Try using the gear in the editor to build a poll.
If you try it, good luck and get stuck
Since no one has the Licensed Badge I will assume no one ever started the “advanced tutorial” or no one finished it.
I would love to finish the tutorial
Hi! To find out what I can do, say @discobot display help.
Found a solution.
You can skip a step in a tutorial when you reply skip.
Quote:
Hey @BrutalBirdie, just checking in because I haven’t heard from you in a while.
To continue, reply to me any time.
If you’d like to skip this step, say skip.
To start over, say start advanced tutorial.
If you’d rather not, that’s OK too. I’m a robot. You won’t hurt my feelings. :sob:
PS:
Now I am the only Licensed User
Still, is this intended? Why is pol blocked?
You will receive the following message when you get promoted to “Member”. (but I didn’t notice… or forgot about that…)
Now that you’ve been promoted, it’s time to learn about some advanced features!
Reply to this message with @discobot start advanced tutorial to find out more about what you can do.
We invite you to keep getting involved – we enjoy having you around.
Probably to be able to use some feature you will need to be promoted to “member”.
In the end I think everything is working as intended
