I have the data with retention policy ‘X’. Can I change the retention policy to ‘Y’ for that existing data?
Hi @aditya,
You cannot replace the retention policy
for existing data but you can alter the
existing retention policy.
You can also create a new retention policy
and copy your data into that new retention policy.
Hope this helps …
@MarcV
Thanks for your response. If we delete the retention policy, then all the data in that RP will have default RP for that database. right ?
Hi.
If you delete the retention policy,
it will remove all your data in that RP!
That makes sense. Thanks !
