I am very thankful to you guys for the help. Specially to @Anaisdg. I learn a lot and many more to learn.
My problem is i want to do a IN operation like SQL -
SELECT column_name(s)
FROM table_name
WHERE column_name IN (value1, value2, ...);
I want to apply the same with Flux.
Can you share any example for this.
@debnath That isn’t specifically available. The way to effectively achieve this is to use either regexp if the naming follows a pattern…or a string of or statements when filtering if it does not.
Thank you @samdillard for the help. Appreciated
@samdillard this is perfect. Thank you.
One request, I have posted a question 2days back no one replied. can you please help me out with that issue?
Link - Need result with Nested Json Object based on group
