debnath
January 21, 2022, 10:35am
1
My problem is -
I need to group my data with one of my column.
I need to jsonify (nested) and return json object
My query is like -
import "json"
from(bucket: "TESTDB")
|> filter(fn: (r) => r["_measurement"] == "data_a9313")
|> map(fn: (r) => ({ r with
jsonStr: string(v: json.encode(v: {"time":r._time,"data":r.call_id}))}))
|> keep(columns: ["jsonStr","assetId"])
|> group(columns: ["assetId"])
|> yield()
I got a solution which stringify the json object may be.
I need the end result as group asset_id like -
"assetId": {
"time" : <_time>,
"call_id": <call_id>
"assetId": {
"time" : <_time>,
Example -
"67egjwqeh": {"call_id":785,"time":"2021-08-28T00:39:21.17Z"},
"uiwey87rew": {"call_id":112,"time":"2021-09-27T00:39:21.17Z"},
"lkda789": {"call_id":112,"time":"2021-09-26T00:39:21.17Z"}...
Can you help me out how can i do that.
Thank you
@debnath can you share what the table/s look like before the pivot()?
@samdillard
Before pivort() it look like this -
Thanks, I think something is missing here. I’m unclear where the original screenshot’s JSON string came from. Where is “mean” coming from? Where is “location” coming from?
@samdillard
Sorry i gave you the wrong one small mistake -
import "json"
|> filter(fn: (r) => r["_measurement"] == "sensor_data_a9313")
jsonStr: string(v: json.encode(v: {"time":r._time,"call_id":r.call_id}))}))
|> yield()
You can consider this -
JSON String i have done for experiment purpose -
I did pivort() first then each row value i made as a JSON string.
I did string but need object.
Except those mistakes you can follow my above requirement and expected output example.
Thank you
In the original question, you wanted:
"assetId": {
"time" : <_time>,
in each jsonStr column, right?
Can you not just add the assetId field directly, like:
jsonStr: string(v: json.encode(v: {"assetId": {"time":r._time,"data":r.call_id}}))}))
@samdillard
Thanks for the reply. But that’s not that i looking for.
Actually i want the whole result on one line.
This is the result after your solution -
But i am expecting -
"03aec595d95c98c746781d635c464d97": [{
"data": 3279740,
"time": "2022-01-21T12:58:02.399Z"
"data": 3603900,
"time": "2022-01-21T12:58:02.684Z"
"055caa286818d0d18c73196c926ec624": [{
"data": 4041538,
"time": "2021-11-23T11:35:36.103Z"
"data": 1480819,
"time": "2021-11-23T11:35:36.345Z"
"data": 3118567,
"time": "2021-11-23T11:35:36.591Z"
There may be millions of assetId and millions of data corresponding to each asset. So I’m expecting that whole result as JSON object and in 1 record.
It might look like this -
Is that possible?
Interesting you’d want this in a single record. Can you come over to the Slack community so we can chat more efficiently? https://influxdata.com/slack
Once there, feel free to DM me at @Sam Dillard
