I’m pretty new to influxDB and to SQL. So i’m not sure it’s possible what i’m trying to accomplish.
I’ve setup a datapush from my Domoticz server to influxDB to create graphs in Grafana. This al works and I love the way it all looks.
But, Domoticz sends the total gas usage instead of the current use. What I want to do is show a Singlestat with the usage of this day. What I came up with is. I get the last value of yesterday and subtract that from the last value of today. That will give me todays usage.
So to test this I have 2 querys (doing the above but then with 4 hours apart):
- 10 minutes ago:
curl -i -XPOST ‘http:/0.0.0.0:0000/query?pretty=true’ --data-urlencode “db=domoticz” --data-urlencode “q=SELECT last("value") AS sum_lastNow FROM "Gas-usage" WHERE time >= now()-10m LIMIT 1”
Result:
“name”: “Gas-usage”,
“columns”: [
“time”,
“sum_lastNow”
“values”: [
“2019-01-23T14:15:48.764348885Z”,
114.633
4 hours ago:
curl -i -XPOST ‘http:/0.0.0.0:0000/query?pretty=true’ --data-urlencode “db=domoticz” --data-urlencode “q=SELECT first("value") AS sum_lastYes FROM "Gas-usage" WHERE time >= now()-4h LIMIT 1”
Result:
“columns”: [
“time”,
“sum_lastYes”
“values”: [
“2019-01-23T10:23:11.87750021Z”,
114.153
So that works. But now i want to combine the 2 and subtract them:
curl -i -XPOST ‘http:/0.0.0.0:0000/query?pretty=true’ --data-urlencode “db=domoticz” --data-urlencode “q=SELECT "sum_lastNow" - "sum_lastYes" AS result FROM (SELECT last("value") AS sum_lastYes FROM "Gas-usage" WHERE time >= now()-4h LIMIT 1), (SELECT last("value") AS sum_lastNow FROM "Gas-usage" WHERE time >= now() -10m LIMIT 1)”
So this results:
“columns”: [
“time”,
“result”
“values”: [
“2019-01-23T14:22:38.550934512Z”,
null
null
Maybe this isn’t even possible or i’m just doing it stupidly.
Any advise would be welcome.
(i’ve changed the ip’s and ports and also the http part, got an error i can only post 2 links)
Greetings,
Jos
