I’m using the http_response plugin to monitor the health of a couple of APIs. The plugin gives the data back in a format that makes it inconvenient to calculate my required outputs:
- Success rate
- Mean response time
- p50, p95, p99 response time
So I’ve turned to kapacitor. I have a working TICK script below to do this and would love some feedback on how to DRY this script up or any advice on my approach!
// kapacitor define success-rate -type stream -tick test.tick -dbrp telegraf.autogen
var period = 1m
var every = 1m
// This is number of points per period, my collection interval is 5s
var points = 12
var groupBy = ['service','testName']
var data = stream
|from()
.database('telegraf')
.retentionPolicy('autogen')
.measurement('http_response')
|groupBy(groupBy)
|window()
.period(period)
.every(every)
.align()
// Calculate the number of successful requests for a time period
var success_rate = data
// Filter out points with unexpected status codes and with no response_string_match
|eval(lambda: "http_response_code" < 302 AND "response_string_match" == 1)
.as('response_time')
|count('response_time')
.as('count')
// Divide coint by expected number of points to come through filter
// Optional * 100 for more readable %
|eval(lambda: (float("count") / float(points)) * float(100))
.as('success_rate')
// Mean response_time in ms
var response_time = data
|delete()
.field('response_string_match')
.field('http_response_code')
|mean('response_time')
.as('mean')
// Turn s into ms
|eval(lambda: "mean" * float(1000))
.as('res_time_ms')
// p50 response_time in ms
var p50 = data
|delete()
|percentile('response_time', 50.0)
.as('p99')
|eval(lambda: "p99" * float(1000))
.as('res_time_ms')
// p95 response_time in ms
var p95 = data
|delete()
|percentile('response_time', 95.0)
.as('p95')
|eval(lambda: "p95" * float(1000))
.as('res_time_ms')
// p99 response_time in ms
var p99 = data
|delete()
|percentile('response_time', 99.0)
.as('p99')
.as('res_time_ms')
success_rate
|join(response_time,p50,p95,p99)
// Field names will be request.success_rate, mean.res_time_ms, p50.res_time_ms, p95.res_time_ms, p99.res_time_ms
.as('request', 'mean','p50','p95','p99')
.tolerance(1s)
|influxDBOut()
.create()
.database('telegraf_derived')
.measurement('http_response_rates')
CC @nathaniel, @michael
