Build sum values from multiple buckets in a single graph
Hi
I have two buckets with same structure and I want to build a graph with sum of values from both of them (background: I read values from 2 different power meters and want to build the total sum)
I can have both values with two lines with
power0 = from(bucket: "power0")
  |> filter(fn: (r) => r["_measurement"] == "power")
  |> filter(fn: (r) => r["_field"] == "value")
  |> filter(fn: (r) => r["ident"] == "15.7.0")
  |> keep(columns: ["_time","value"])
power1 = from(bucket: "power1")
  |> filter(fn: (r) => r["ident"] == "16.7.0")
union(tables: [power0, power1])
But I want to have a single line with sum of both values (“15.7.0” from power0 and “16.7.0” from power1)
how is that possible?
Hello @Holger_Seehausen,
You can do:
  |> sum()
  |> sum()
join(tables: {power0: power0, power1: power1}, on: ["_time"])
Thanks, after some more investigation I think this is a better solution and more flexible solution, if you need other calculation as well
see here: this returns only the “sum” of the two queries
  |> aggregateWindow(every: 5m, fn: mean, createEmpty: false)
join(tables: {power1: power1, power0: power0}, on: ["_start", "_stop", "_field",  "_time"])
  |> map(fn: (r) => ({ r with _value : r._value_power0 + r._value_power1 }))
  |> drop(columns: ["_value_power0", "_value_power1"])
Helllo @Holger_Seehausen,
Thanks for sharing!
