When I build telegraf from source code on master branch.
Command:
make package include_packages="tar.gz"
Error Message:
[root@ops-2 telegraf]# make package include_packages="tar.gz"
env -u GOOS -u GOARCH -u GOARM -- go build -o ./tools/custom_builder/custom_builder ./tools/custom_builder
env -u GOOS -u GOARCH -u GOARM -- go build -o ./tools/license_checker/license_checker ./tools/license_checker
env -u GOOS -u GOARCH -u GOARM -- go build -o ./tools/readme_config_includer/generator ./tools/readme_config_includer/generator.go
env -u GOOS -u GOARCH -u GOARM -- go build -o ./tools/config_includer/generator ./tools/config_includer/generator.go
env -u GOOS -u GOARCH -u GOARM -- go build -o ./tools/readme_linter/readme_linter ./tools/readme_linter
go generate -run="tools/config_includer/generator" ./plugins/common/...
go generate -run="tools/readme_config_includer/generator" ./plugins/common/...
go generate -run="tools/config_includer/generator" ./plugins/inputs/...
go generate -run="tools/readme_config_includer/generator" ./plugins/inputs/...
go generate -run="tools/config_includer/generator" ./plugins/outputs/...
go generate -run="tools/readme_config_includer/generator" ./plugins/outputs/...
go generate -run="tools/config_includer/generator" ./plugins/processors/...
go generate -run="tools/readme_config_includer/generator" ./plugins/processors/...
go generate -run="tools/config_includer/generator" ./plugins/aggregators/...
go generate -run="tools/readme_config_includer/generator" ./plugins/aggregators/...
go generate -run="tools/config_includer/generator" ./plugins/secretstores/...
go generate -run="tools/readme_config_includer/generator" ./plugins/secretstores/...
generating default config
go run ./cmd/telegraf config > etc/telegraf.conf
if [ ".gz" = ".zip" ]; then go generate cmd/telegraf/telegraf_windows.go; fi
cp: missing destination file operand after '/usr/local/bin'
Try 'cp --help' for more information.
make[1]: *** [install] Error 1
make: *** [tar.gz] Error 2
My os version and make version:
# centos 7
CentOS Linux release 7.9.2009 (Core)
# make version
GNU Make 3.82
Built for x86_64-redhat-linux-gnu
Copyright (C) 2010 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law.
Some help Please?
